Author Topic: venox  (Read 472 times)
yumzsmw
venox
« on: August 19, 2018, 05:56:34 AM »
i was riding home stopped for train when i started to go it only ran on one cylnder i limped home compression checked out good valves setting good has good spark when i turn it over to start there is a deep throaty sound from exhaust ?
Small CC TEK
Re: venox
« Reply #1 on: August 20, 2018, 03:33:47 AM »
Need more info  , I loved that bike when it was in the US ..  Did you do all the easy stuff first ?   Look and  see if the coil to that cylinder is working  , spark , look at the plug etc ...
Viper254
  • Moped Pirate
Re: venox
« Reply #2 on: August 20, 2018, 09:08:36 AM »
If you've got good compression and good spark, you're looking at fuel most likely.
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
yumzsmw
Re: venox
« Reply #3 on: August 25, 2018, 02:13:34 AM »
ya got spark compression but when i turn it over it sounds different then it did before
hypophthalmus
Re: venox
« Reply #4 on: August 25, 2018, 02:52:08 AM »
Does the Venox have a single carburetor? Or two?
