Author Topic: Heres one for ya...  (Read 963 times)
Lostinsperry
Heres one for ya...
« on: August 21, 2018, 03:37:00 PM »
Hello everyone! Im new here today..  at my whits end with this fn machine..  have had a super 8 2t for about 5 years now..  just put the big bore on n did a whole bunch to the cvt..  grabbed the 17mm carb for it and It will start and idle but only for about 5 seconds then die.  If it starts it wont rev up much if any then die again..  Im not an expert on 2 strokes so any input would be helpful!  Thanks guys!
Lostinsperry
Re: Heres one for ya...
« Reply #1 on: August 21, 2018, 05:09:37 PM »
Ok I got it tuned to where it will start and idle, but not long, and I can rev it up some before it dies but it doesnt sound right anyways..  Idk what Im doin wrong.. everything was supposed to be bolt on n go.. 😧
Murphychow@gmail.com
« Reply #2 on: August 27, 2018, 02:03:45 AM »
Which kit? Compression readings?  U installed it correctly?  The 2 dimples on the piston should be facing up where the intake is. If u bought Naraku kit it's most likely f***ed.
Chris0381
« Reply #3 on: August 27, 2018, 10:47:48 AM »
You increased the intake of air and fuel. Did you increase to out take of air and fuel ? Is it a 2 stroke ?
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
