Author Topic: Is there even such a thing?  (Read 616 times)
EvilTessmacher
« on: August 22, 2018, 11:51:33 AM »
I was thinking yesterday about how I'm going to go about removing and replacing the screws which hold the cover plates over the backs of the turn signals. I have been using two different phillips screwdrivers to do it, a 4" and a 9". The reason for that is that I've not removed the back plastic, but only the luggage bucket. There's a support (on each side) that holds the seat-latch mechanism welded to the frame, in exactly the place I need to be to have straight-in direct access to the screws. As it is, I have to approach the screw at a very slight angle to get them out, and I have to tape the screw to the end of the driver to hold it in place to even get it back in.
This got me to thinking... (dangerous, I know, right?)
Is there such a thing as a flexible screwdriver?
If I could "bend" the shaft of the screwdriver around that damn seat-latch mechanism, I could get straight into the screw, and not worry about stripping out the head.
Is there such a thing as a flexible screwdriver? And where, oh where, would I even go to find one?
Enquiring minds, and all that...
Two things to consider...
2018 Kymco 400i - "Diana"
2013 Honda PCX - "Natasha"
1982 Honda PA-50
boo
YES I used to have one
« Reply #1 on: August 22, 2018, 01:07:49 PM »
Don`t know where it is right now. The problem I found with this screw driver was, you could not get a tight screw loose with it because it flexes too much. For that reason it fell out of favor with me.
300GTI black
Pro 2A - member GOA & NRA
Fogie
Possibly Helpfeul
« Reply #2 on: August 22, 2018, 01:28:54 PM »
There's a few items here that might help:
https://www.amazon.com/slp/offset-screwdriver/kp6hpxdvyj697fa
2012 Kymco Frost (Yager) 200i - Toronto, Canada
Clampett
  • Uncle Jed
    • My Maps
Re: Is there even such a thing?
« Reply #3 on: August 22, 2018, 02:54:38 PM »
I've not looked yet, so this is just a question:
Could you get to it from the bottom using one of those Z shaped screw driver tools?
I've not looked and when I get to it later, I'll probably go duh!!!!!
EvilTessmacher
« Reply #4 on: August 23, 2018, 03:05:43 AM »
Well, I had to go to Lowe's anyway, to pick up another electrical plug outlet for the garage, so I asked the guy in the tool department if there was such a thing, and he took me right to it. Needed to get a #1 phillips head, but it did the trick! More to come...
1982 Honda PA-50
Clampett
  • Uncle Jed
    • My Maps
« Reply #5 on: August 23, 2018, 04:15:30 AM »
Kewl beans!!!!
EvilTessmacher
« Reply #6 on: August 23, 2018, 10:29:33 AM »
Given the late hour, and  how tired I was, I admit being seriously remiss in not posting more information.
Here's what I ended up getting:
https://www.lowes.com/pd/Kobalt-1-4-in-Spinner-Handle-with-Flexible-Shaft/3382208
The only thing I needed to add to it was a 1/4" socket, which I already had, and a #1 phillips bit, which I wasn't sure if I had and bought just in case. Turned out I didn't have any, and needed them. The only thing that would have been better about this, is if the bits were magnetic. That would have helped a lot.
1982 Honda PA-50
stuo
« Reply #7 on: September 12, 2018, 07:36:10 PM »
Hey Evil T,
You can magnetize your screwdriver bits by rubbing them in one direction on a magnet.
2009 GV 250
« Reply #8 on: September 13, 2018, 04:26:21 PM »
  I took the magnet off of a cabnet door , and stick it on any screw driver, so all my old screw drivers are magnetic now
stuo
« Reply #9 on: September 13, 2018, 06:32:05 PM »
Good one, de dee.
2009 GV 250
