Author Topic: Indling fluctuate  (Read 2731 times)
gabor
Indling fluctuate
« on: August 22, 2018, 03:26:11 PM »
Hello! Kymco Xciting 250i, I have now replaced engine oil, gear oil and air filter. I did not fill too much. From then, the idle fluctuates constantly, spinning the wheel. Does anyone have an idea of what to do, has anyone had any similar experience? Thanks in advance!
xsel777
Re: Indling fluctuate
« Reply #1 on: August 22, 2018, 08:51:25 PM »
Air leak ?
« Reply #2 on: August 23, 2018, 01:32:40 AM »
Air leak ?
That sounds good.....airbox was disturbed doing the filter.  Intake rubber cracked, loose, leaking in air?
Worth a look!
gabor
« Reply #3 on: August 23, 2018, 04:48:15 AM »
Thank You, I will check...
gabor
« Reply #4 on: August 23, 2018, 07:15:29 AM »
Unfortunetly does not leak the air :( Still the same problem... Maybe across the new filter get more air?
« Reply #5 on: August 23, 2018, 10:56:56 AM »
Try old filter again?
gabor
« Reply #6 on: August 23, 2018, 01:37:29 PM »
Not yet, that will bo the next... Thank You
