Author Topic: Rear Turn Signal Conversion to OEM LED - 2018 Xciting 400i ABS - SK80AL-US  (Read 2672 times)
Clampett
  • Uncle Jed
    • My Maps
Must use the right gauge clips for the correct size wire with those in the video.
Another thing I do, I use the pliers like he did, BUT I clip the blade down BEFORE folding over the cap.
You can see the blade start to come through the cap.
By clipping it before you close the cap, you can make sure the blade is completely seated and even.
The cap can even be closed by hand then.
EvilTessmacher
It all comes down to doing what works, staying within one's comfort zone, and the shared experiences of like-minded individuals on forums like this one...
Two things to consider...
2018 Kymco 400i - "Diana"
2013 Honda PCX - "Natasha"
1982 Honda PA-50
AlexisStarlyn
Re: Rear Turn Signal Conversion to OEM LED - 2018 Xciting 400i ABS - SK80AL-US
« Reply #17 on: September 04, 2018, 01:04:34 PM »
Just did this yesterday, accidentally only ordered a single cable, so I desoldered the female end from the board, and soldered in my own wires straight to one of the boards.
Absolutely love the look of the OEM turn signals
EvilTessmacher
« Reply #18 on: September 05, 2018, 02:01:20 PM »
Dude, you got a lot more guts than me. I wouldn't fool with a PCB if my life depended on it. Too much opportunity to screw it up permanently.
And you gotta post pics or it didn't happen!  ;D ;D
1982 Honda PA-50
