Author Topic: tank capacity  (Read 1338 times)
davide
tank capacity
« on: August 24, 2018, 09:06:27 AM »
Hi,
I have a problem, when I gasoline in the tank of my scooter s 200 people do not enter more than 3 liters. what could be the problem?
The capacity is not 6 liters?
Greetings
Tri750
Re: tank capacity
« Reply #1 on: August 24, 2018, 09:35:13 AM »
I show the capacity at 6.8L
so if the gas pump is shutting off and your Gascon gauge is not showing full, remove the nozzle a bit and continue to fill the tank a small amount at a time with the nozzle tip quite close to the tank opening to get a full tank. NOTE : always fill the tank on the main stand or called the centerstand !
As use of the side or prop stand will prevent the entire tank to be filled.
After visually checking for full tank, and a few minutes pass, the fuel Gaige should read full.
If it does not, you may have an issue with the tank gauge sender.
