Author Topic: Turn signal issue  (Read 433 times)
orrn1991
Turn signal issue
« on: August 25, 2018, 07:28:30 PM »
Just got my scooter Thursday.  That evening the right turn signal started blinking fast like hazard lights.  The right turn signal light works in the rear but does not work in the front.  Changed the light bulb in the front and it still does the fast blinking and no light in the front.  Left side works as it should.  Ideas?  Thanks for your help
Re: Turn signal issue
« Reply #1 on: August 25, 2018, 07:40:45 PM »
Welcome to the forum...…
Connection in the front Right light socket sounds like it is not making good contact with the bulb.
Put turn signal on, and try wiggling bulb around.
I'd look closely at that socket....if all looks good - a wire connection may be unplugged at the light or the relay.
New scooter?
....return to dealer for the fix.
« Last Edit: August 25, 2018, 07:44:49 PM by Stig »
