Author Topic: Little loss of throttle response  (Read 2457 times)
agilebda
« on: August 30, 2018, 01:40:36 AM »
Hello guys. Losing a little snap take off on the low end. Hard to explain but it does not seem to have that "throw you back torque on take off like she did before.
I am almost due for a 5k service. I was thinking about changing the fuel filter this time as it is really black like a lump of charcoal.
Variator Rollers may be done and dusted perhaps? They've never ever been changed in the 6 yrs I've had my scoot.
What are your thoughts? 50k on the odo.
Re: Little loss of throttle response
« Reply #1 on: August 30, 2018, 02:00:33 PM »
Could be a little wear on the CVT stuff. New rollers are cheap, cleaning costs only your sweat and a new belt could not hurt (unless it is recently replaced).
agilebda
« Reply #2 on: August 30, 2018, 06:43:30 PM »
Hello Crossbolt.
I came to the same conclusion. Thanks very much for your help. I've ordered CVT clutch shoes and all springs to see if she comes back to low end life. Also have 14gram 20×12 rollers and a new belt to try as well. Full service of the CVT
Regards
« Reply #3 on: August 30, 2018, 10:10:24 PM »
That new belt is a Kymco genuine part, right?
agilebda
« Reply #4 on: August 30, 2018, 10:35:12 PM »
Will be this time. I have a malossi belt at the moment.
« Reply #5 on: August 31, 2018, 03:35:44 PM »
A-HA! (maybe...)
agilebda
« Reply #6 on: August 31, 2018, 04:25:22 PM »
CROSSBOLT, you have me thinking if that's the root of the problem..
« Reply #7 on: August 31, 2018, 08:24:24 PM »
Anything I can do to spoil yer day! Well, maybe that's it and maybe it isn't. But what I have seen on here the consensus is the Kymco belts (Mitsuboshi) are the best.
agilebda
« Reply #8 on: August 31, 2018, 09:07:02 PM »
Well I have heard that Malossi will eat anything that isn't Malossi....lol. I've see lots of horror stories in that regard.
Thanks again for the info buddy.
agilebda
« Reply #9 on: October 03, 2018, 07:59:41 PM »
Crossbolt, other than belt what else do you recommend replacing with my hours/miles? Rollers? Springs? Entire Variator?
Thanks
« Reply #10 on: October 03, 2018, 09:12:05 PM »
Only stuff that is worn badly or beyond limits (if known) the obvious stuff. I ran rollers with flat spots in the original DT and they worked fine. The flat spots indicate less weight probably too small to make a difference. I am probably not the one to ask because I have not worn anything out yet! Well, did have to replace a belt because the air inlet was blocked by mouse-hoarding birdseed causing the CVT to overheat. New Kymco belt fixed her up!
agilebda
« Reply #11 on: October 17, 2018, 09:48:25 PM »
Commenced a full service today. Check this out. Lots of play in the belt. Probably the issue right here!
boo
« Reply #12 on: October 17, 2018, 10:21:00 PM »
Might be a good idea to check to see if the throttle cable has stretched.
300GTI black
Pro 2A - member GOA & NRA
agilebda
« Reply #13 on: October 17, 2018, 10:27:49 PM »
Haha. Good one! ;D
« Reply #14 on: October 18, 2018, 01:35:47 AM »
The video reveals the front pulley assembled incorrectly in that the two sides of the pulley not as close together as they should be OR incorrect belt (too long).
