Author Topic: LIKE's birth cert., valves & Dr Pulleys  (Read 454 times)
« on: September 02, 2018, 04:18:58 PM »
Came across these photos today...
The spark plug hole. It is beneficial to keep things clean under here.
EXhaust valve clearly marked. Moot point, since both are set to the same clearance on this scooter.
If you have up/down movement in those rocker arms, and this position on this sprocket, you have TDC for setting/checking the valves.
Proper position for Dr Pulley sliders in a LIKE200i. Amazing how often folks don't, or let them flip when placing on the scooter.
