Author Topic: 2008 Venox 250 Idling problem  (Read 2440 times)
SMS
« on: September 02, 2018, 07:10:39 PM »
I have a 2008 Venox 250 with only 950 Klm (yes nine hundred and 50 clicks).  It's been stored and I left bad gas in her.
Removed the Carbs and cleaned all jets, orifices etc, etc three times. Fresh gas. Tested vac fuel valve all good.
She will only run on full choke.  When choke is closed she stalls. Turning in air screws make no difference. Ran her around the block a couple of times with choke off and bike runs ok.  Will not idle, even with idle adjust knob turn in full. Screws are backed out to 2 turns.
I have the service manual, unfortunately it's not much use, in my case.  Does not even have a hose routing diagram, and the one under the seat is not as fitted.
My assumptions;
Only idles with choke on is an indication to much idle air. Turning in screws makes no difference.
Or I have an air leak.  If anyone can provide a detailed emissions control hose diagram would be extremely helpful, or if anyone has experienced the same problem kindly let me know.
Thanks to all.
Robertchanger
Re: 2008 Venox 250 Idling problem
« Reply #1 on: September 02, 2018, 09:28:40 PM »
Yeah the manual is kind of useless .  I had the exact same problem two months ago.  This helped me out.  Turned out a loose hose was turned downwards with the puke tubes.
http://www.kymcoforum.com/index.php?topic=14679.0
Robertchanger
« Reply #2 on: September 02, 2018, 09:29:30 PM »
Look at Pebbles's Imgur link
SMS
« Reply #3 on: September 04, 2018, 04:37:20 PM »
The pictures of the hoses was very informative, unfortunately all my hose connection are as per the pics.  Bike still not idling  without choke.
Thanks for the prompt and very useful info though.  Any other ideas would be most welcome. Can't find any external air leaks.
Regards,
Robertchanger
« Reply #4 on: September 04, 2018, 04:57:31 PM »
Um air filter?
Robertchanger
« Reply #5 on: September 04, 2018, 05:00:33 PM »
Or spark plugs?
SMS
« Reply #6 on: September 04, 2018, 08:13:31 PM »
Thanks Robert.  Air filter and plugs are good.
Cheers.
dj103086
« Reply #7 on: August 09, 2019, 08:14:36 PM »
I have a 2007 kymco venox with 21000km on it.  I had a similar issue when I left fuel in for the winter as well.  I ended up getting lots of debris in the tank and had to reseal the tank and also take the carbs completely apart and clean them  I took them apart and then let them sit in solution for 3 days then cleaned them even more by hand as I put them back together.  If you go this route be very carful with the float bowl they are very touchy and getting them to sit at the right level was a pain in the butt.  Bike runs great now again.  good luck.
