Author Topic: No spark  (Read 5075 times)
art
Re: No spark
« Reply #15 on: August 15, 2010, 05:01:41 PM »
 Unfortunatly mine was the generater  :'(
jswalls110
Re: No spark
« Reply #16 on: August 16, 2010, 01:22:01 PM »
I will certainly look at that. thanks.
jswalls110
Re: No spark - FIXED
« Reply #17 on: September 01, 2010, 11:24:25 PM »
Some more screwing around tonight, and bingo I find it! I took the front cowling off, and starting looking at the plugs. Unplug, replug. Test ignition. Turns out, on the plug up to the ignition switch itself, there is a single wire black/white coming from the top (12 oclock) from the switch. I unplug it, and it fires right up. Run for a while, shut down, start up. Several times. Then a quick ride.
No shut off. I assume this is an off position, and also assume I have to replace the switch. It starts up and shuts off no issues. So for now, I have the plugged taped off.
Where can I get a new ignition switch, and what the hell is that wire?
Thanks for all the help too!
Re: No spark
« Reply #18 on: September 01, 2010, 11:27:08 PM »
.."http://www.stadiumyamaha.com" for all your kymco OEM parts...mention this forum!!
peace
art
Re: No spark
« Reply #19 on: September 01, 2010, 11:44:33 PM »
  Yay!  ;D  Who needs it!  ;)  Try to clean and reseat it. May need to clean the contacts at the switch also with electrical contact cleaner it can work wonders sometimes. Not sure what the wire is. but another thought is if the cleaning don't do it,you might want to trace that wire out may be grounding out somwhere else. Saved your self a shop visit at least.
« Last Edit: September 01, 2010, 11:57:56 PM by art »
Re: No spark
« Reply #20 on: September 01, 2010, 11:45:12 PM »
..i'm not seeing a bl/w wire on my schematic...hmmm..
..what other color of wires come from that switch??
jswalls110
Re: No spark
« Reply #21 on: September 02, 2010, 12:13:41 AM »
Ok, I had to take the cowl off again, can't trust my memory.
The ignition switch has 5 wires coming out of it.
12 oclock Black/White
2 oclock Black
5 oclock Green
7 oclock Green
10 oclock Red
The Blk, 2 Greens and Red all go to a connector. The Blk/White runs outside that group and goes to a single wire (barrel?) connector.
And I like the idea of the electrical contact cleaner too. MIght have to give it a try.
Re: No spark
« Reply #22 on: September 02, 2010, 12:18:36 AM »
..is there a fuse in that connector??
jswalls110
Re: No spark
« Reply #23 on: September 02, 2010, 12:19:20 AM »
Nope. It's about 6 inches from the ignition switch.
Re: No spark
« Reply #24 on: September 02, 2010, 12:21:42 AM »
..can you take a pic??
..i don't see those color wires on the wiring schematic from the start switch...
..only green and yellow/red...
..that sounds like the keyswitch...
jswalls110
Re: No spark
« Reply #25 on: September 02, 2010, 12:23:01 AM »
Sorry, my fault. Thats an IT guy trying to talk mechanics. It is the key switch.
art
Re: No spark
« Reply #26 on: September 02, 2010, 12:25:41 AM »
  Does that model have the sidestand kill switch? Maybe that is it  ???
Re: No spark
« Reply #27 on: September 02, 2010, 12:27:22 AM »
..no, that's cool...similar, but still different that the schematic i have...
..what year is ur scoot??..might can find another schematic...
Re: No spark
« Reply #28 on: September 02, 2010, 12:28:25 AM »
..as far asi know, tere are no a50s with kill switches other than on the right handlebar...
jswalls110
Re: No spark
« Reply #29 on: September 02, 2010, 12:29:58 AM »
Ok thought it was 2008, title says 2007. And there is no kill switch on the kick stand, only the right handlebar.
