Author Topic: 2013 agility timing chain removal/adjusting  (Read 684 times)
2pac
« on: September 10, 2018, 10:34:04 PM »
hello
i actually own a 125 Movie but i guess the agility has the same or very similar motor.
my valve timing is probably one tooth out. is it possible to remove and re-install the chain after releasing the tensioner without removing the camshaft? if not- what tool is required to open one link in the chain?
thanks
118118
Re: 2013 agility timing chain removal/adjusting
« Reply #1 on: September 11, 2018, 09:40:22 PM »
You can remove the chain from the cam gear with the tensioner removed & the cam still bolted in place, if I remember correctly.
