Author Topic: 2016 piaggio 350 oil change at 20,063 Km.  (Read 539 times)
« on: September 14, 2018, 05:42:14 AM »
 ;D ;D ;D
  did the oil change  and gear oil  cleaned the variator  new rear tire at 13,000 Km.   dealer took pictures of the gas tank as I told him it crushed up as I used the gas now it takes 9 Lts to fill  instead of 14.5 Lts.  hope new tank gets here for the winter lots of time for down time   4 months of snow
PaulF
Re: 2016 piaggio 350 oil change at 20,063 Km.
« Reply #1 on: September 14, 2018, 06:35:49 AM »
How did your tank get crushed?  I am enjoying my Piaggio Medley a lot but may upgrade to the Beverly in a couple of years.
« Reply #2 on: September 14, 2018, 11:14:31 AM »
Sounds like bad plastic molding....too thin? Tank collapsed as fuel emptied. ....crazy!
« Reply #3 on: September 14, 2018, 07:06:25 PM »
The Evap system may have done it as there was major vacuim  when I opened the gas cap,  then I filled with gas I could only put in 5.6 Lt.s  so I pulled the tank hose off and pumped 10 Lb. of air in it and it poped out to 9.6 Lt.s on a fill,.  now I am waiting for a new tank ,
« Reply #4 on: September 15, 2018, 01:57:05 PM »
Yeah! The vent valve stuck and the fuel pump caved in the plastic tank! Har, har!
« Reply #5 on: October 31, 2018, 01:43:34 AM »
 ;D  the new tank came in and I removed old tank,   the only thing is the tank is wrong one the gas filler cap is wrong, so parts all over the floor, in garage,  all the tupper ware is off,  It is a good time to do the valves , found out all I need is two valve shims # 285 @ $11.00 each,  pull a clip out beside the rockers and then slide the rockers over and switch shims 280 to 285 on the intake valves then push the clip back in ,.  so quick.,   and so easy with the gas tank out of the way,.   the shims are 9.45 mm wide and thickness is now 285 mm.   they look like small round batterys for a watch,.
« Reply #6 on: October 31, 2018, 11:39:20 AM »
I bought a full set of shims off Ebay for $35.
Fellow just used 2....there were several of each....so he sold it as "full set".
Bought the set for my Honda Forza, after seeing how much Honda wanted for one shim!
Hope you get that crazy tank situation sorted!
« Reply #7 on: October 31, 2018, 04:51:30 PM »
Oh, that really sucks! So many evil thoughts/emotions to be suppressed when that happens. Hope it gets sorted without too much pain!
