Author Topic: Kat Needs Help :D  (Read 2019 times)
kneeslider
Re: Kat Needs Help :D
« Reply #30 on: September 24, 2018, 01:02:37 AM »
In my experience, the best belts for scooters are the originals.
Aftermarket ones even Malossi, their belts are a little outside of the original Kymco specs. So that is not ideal.
Original is best at this stand point.
2019 Yamaha X-Max 250
Nireen
« Reply #31 on: September 24, 2018, 01:04:05 PM »
Kat needs a belt! badly! LOL wowzer.  Just came from the garage took off the covers and the belt had a couple chunks out of it! LOL lots of cracking to.  So does this reveal how hard I am on it?
Kat :)
« Reply #32 on: September 24, 2018, 01:20:50 PM »
I had one like that but the ventilation was stopped up by mice packing seeds in the cover blocking the intake. The CVT runs hot anyway so, yeah, you may ride too hot!
Nireen
« Reply #33 on: September 24, 2018, 01:35:16 PM »
Karl should I clean those little filters in there? one on the outer casing and one on the belt case?
Kat :)
Nireen
« Reply #34 on: September 24, 2018, 01:36:59 PM »
The garage said I was lucky I didn't get stranded on my last trip!
Kat :)
Nireen
« Reply #35 on: September 24, 2018, 03:21:52 PM »
20x12, 15 grams (8 pack)  So this is what I need to order for rollers?  If so I will let the garage know this to help them out. They can't find in their books.
Kat :)
« Reply #36 on: September 24, 2018, 06:02:43 PM »
Kat, if the filter in the aluminum belt case is dirty, cleaning should be vewy, vewy carefully done! Elmer Fudd says that foam tears vewy easily! Dint know there was a filter in the plastic CVT cover...
Nireen
« Reply #37 on: September 24, 2018, 06:22:05 PM »
My manual don't have one but I do on my bike! I will ask the garage when to make the change to clean it. :) Thank you Karl
Kat :)
hypophthalmus
« Reply #38 on: September 24, 2018, 06:58:25 PM »
That's correct on the rollers.
Nireen
« Reply #39 on: September 24, 2018, 07:02:39 PM »
good cause I just ordered them in from the states :)
Kat :)
kneeslider
« Reply #40 on: September 25, 2018, 01:37:57 AM »
I believe some models have them.
Nireen
« Reply #41 on: September 25, 2018, 09:50:28 AM »
It looks like it is pretty important to clean up that filter on my CTV COVER.
Kat :)
« Reply #42 on: September 25, 2018, 10:50:23 AM »
Good video! No filter in the intake on the DT300i. That would have kept the mice out!
Nireen
« Reply #43 on: September 25, 2018, 08:33:56 PM »
Kat is shocked when I just heard that Kymco dealer wants $9 a roller! really! geeez! The air filter is $40 bucks to. Tell me do you all think I will have to change the rollers now or can I get more time out of them without problems?  I am at 25000kms.
Kat :)
« Reply #44 on: September 25, 2018, 09:01:23 PM »
Not sure what size your scoot takes, but full set of Dr Pulley slider weights run $30-$45. Riders here can advise correct weights to reproduce stock performance.
www.buggypartsnw.com
« Last Edit: September 25, 2018, 09:04:37 PM by Stig »
