Author Topic: People 200s slow getting off the line.  (Read 604 times)
badgas
« on: October 01, 2018, 12:05:35 PM »
Must apply huge amount of throttle to get scoot to start moving. Once it starts moving it's very responsive. What's normal for the 200s, and what might be the problem?
Re: People 200s slow getting off the line.
« Reply #1 on: October 01, 2018, 01:22:43 PM »
That would be directly related to clutch condition: spring strength, pivot of shoes. Also gearbox condition: lube content? How well is the gearbox lubed?
badgas
« Reply #2 on: October 01, 2018, 03:38:07 PM »
Don't know. Just bought this scoot and had planned on assessing its needs this winter. I'll be tearing it down shortly, check it against specs, and, I'm sure, be buying many parts. Thanks for the tip. I'll give special attention to the clutch.
Louder North
« Reply #3 on: October 01, 2018, 04:43:38 PM »
There is a 200s discussion area; you would get a faster response by posting there.   http://www.kymcoforum.com/index.php?board=24.0
2009 Kymco Frost (aka Yager 200i)
10,000 km
bought used in 2018
2007 Aprilia SR50 (Morini motor)
2013 Aprilia SR50 (Piaggio motor)
1986 BMW R80
stuo
« Reply #4 on: October 01, 2018, 07:02:53 PM »
What Karl said...plus inspect the belt.
2009 GV 250
« Reply #5 on: October 02, 2018, 02:20:17 AM »
Badgas,  mine also takes a decent amount of throttle to get it moving. I replaced my clutch last year (didn't need to, just did it...) with a factory clutch and the replacement takes more throttle to move that did my original one....but when it hooks up it really takes off fast..for a scooter. It has a stronger spring in there than the original one...which I take as meaning it needs more throttle to get going.
You may or may not have anything wrong with your scoot...
badgas
« Reply #6 on: October 03, 2018, 11:57:24 AM »
Iahawk - This being my first scoot, I'm unfamiliar with CVT operations. When brand new do they have a little creeping forward at idle, which means that you must use the brake to avoid going forward? How much throttle twist is normal before the scoot starts to move forward?  I've seen some scoots on u-tube, up on center stand and running at low idle,that the drive wheel moved ever so slowly... Being a newbie I've no idea as to what to expect out of my peep....
stuo
« Reply #7 on: October 03, 2018, 06:29:00 PM »
All four of my scoots will have rear wheel slowly turning at idle on center stand but no creep when on ground. Idle speed after warm up is around 1700 rpm.
2009 GV 250
