Hi folks,
My 2006 B&W 150 is draining its battery to totally dead[0] when left without being driven over the weekend.
This happens both with the original, three year old battery, and three month old freshly-charged battery that I put in the scooter prior to the last weekend.
My first thought was that the storage compartment's dome light was somehow not turning off, and so was draining the battery, but I tested it this afternoon and the lamp turns off with the seat closed securely. To be on the safe side, I removed the bulb. The battery draining behavior only started after I put the light bulb in -- when I bought it, there was only the lamp housing but no bulb.
I've taken to keeping one battery on the Battery Tender Jr. at all times, then swapping it out with the one in the scooter after each weekend. Needless to say, it's a bit frustrating, and I fear it may be taking a toll on the battery lifespan.
Any ideas as to what could be causing this rather serious battery drain in such a short time? The scooter resides in Tucson, AZ, but even the heat shouldn't be enough to discharge a battery so deeply in only a few days. I have a multimeter, but it's at home and I won't be able to access it for about a week.
- To the point where my Battery Tender Jr. wouldn't start charging it until I got a bit of a "base charge" from a dumb charger. After that, the Battery Tender Jr. worked fine.
