Author Topic: Polini variator  (Read 2927 times)
glopezz05
Polini variator
« on: August 19, 2010, 04:55:05 AM »
Question...
Will I notice a difference just by installing a polini var?
I'm talking same weights but what weights are you all running?
I'm a big guy and live in the hills.
Im usually on a bicycle, so for me, this thing is hauling ass!
art
Re: Polini variator
« Reply #1 on: August 19, 2010, 05:08:49 AM »
 I like the malossi,but couldn't tell ya the best weights to run. If ya can get a veriater Kit with an after market drive face, you might be interested in some thing like this.  http://www.provoscooter.com/scooters/ruima-racing-variator-139qmb.html  . Dont know the quality of the veriater but has the drive face for a little more top end. Than you might want a little stiffer clutch spring  ;D See how this go's  ;)
art
Re: Polini variator
« Reply #2 on: August 19, 2010, 05:19:33 AM »
 Oh ya there will be a difference, Getting it tuned right can be a little tricky,but not to bad with some support  :D
« Last Edit: August 19, 2010, 05:22:24 AM by art »
ORBITZ
Re: Polini variator
« Reply #3 on: August 19, 2010, 08:20:18 AM »
hi
i´ve got the polini variator, it´s not bad, but for the same price today i would go for the malossi, it includes the main spring , that polini doesnt have. both are very good.
btw i´ve got my new gates belts hehehe.... wicked! doing downhill 95km/h :P straight line 85kmh alone or with two persons it just rocks!
i´ve got to get those gear ratios....
cheers!
art
Re: Polini variator
« Reply #4 on: August 19, 2010, 07:56:31 PM »
 Hey orbitz did you see an upgear for the agility. I would like to see that sight if ya can post it. I think they would work in the people 50 2t also. Thanks
Mwellington
  • 07 Kymco Agility 50
Re: Polini variator
« Reply #5 on: August 19, 2010, 08:25:51 PM »
I just bought an Agiltiy 50, and just ordered the Polini Variator from scooter Dynasty. http://www.scooterdynasty.com/polinihighperformancespeedcontrolvariatorkitsforkymcoscooters.aspx
Has anyone installed this? What were your results? I can't wait to get this installed and test it out. I also just de-restricted the CDI (I think) by making the cut on the end of the CDI box, however I'm not sure if it worked or not. Will I be able to tell a difference?  ???
'07 Kymco Agility 50
art
Re: Polini variator
« Reply #6 on: August 19, 2010, 09:02:09 PM »
  Welcome to the forum, You may need to be going down hill to see if the cdi mod is working You should see an increase in top speed. The polinni should work fine for you. You may have to change your roller weights to get the best results.
 You will need an impact wrench and a 17mm socket to get the nut off the varieter side and a 14mm for the clutch side if doing the spring also.
Re: Polini variator
« Reply #7 on: August 19, 2010, 09:59:18 PM »
btw i´ve got my new gates belts hehehe.... wicked! doing downhill 95km/h  straight line 85kmh alone or with two persons it just rocks!
..wow...love to hear that...another 95 kmh guilty!!!
 ;D
Re: Polini variator
« Reply #8 on: August 19, 2010, 10:00:41 PM »
..welcome to th' Forum!!, Mwellington...
..is this a new scoot??
..if not, how many kms??
peace
Mwellington
Re: Polini variator
« Reply #9 on: August 19, 2010, 10:15:31 PM »
@art: I did a downhill test, and my top speed is now about 45 MPH.
@wordslinger: It's not new, it's an 07 w/ about 3500 km on it.
Re: Polini variator
« Reply #10 on: August 19, 2010, 10:56:58 PM »
...3500...wow..it's still "new" then, lol...
..i got 51,000 on my '08...
 ;D
Mwellington
Re: Polini variator
« Reply #11 on: August 20, 2010, 12:52:34 AM »
 ;D ha! Great! It was an awesome deal too... I bought locally for $600.00 USD.
Re: Polini variator
« Reply #12 on: August 20, 2010, 01:08:25 AM »
..what are, any numbers printed on the top of your carburetor??
Mwellington
Re: Polini variator
« Reply #13 on: August 20, 2010, 01:37:45 AM »
There are two sets of numbers I could find. One, on the top face of the carb- LDC8 or B. The other, on the top right side of the carb was 0214A.
glopezz05
Re: Polini variator
« Reply #14 on: August 26, 2010, 03:20:28 PM »
orbitz, what is the size belt you got?  I think as long as I'm going to be in there I could throw on a new belt.
