Author Topic: Mysterious problem  (Read 1840 times)
Tshu-hash
Mysterious problem
« on: August 19, 2010, 07:04:06 AM »
Hello Everybody,
I have a rather interesting problem with my scooter. While riding the bike the engine suddenly shuts off without any previous signs. When I turn the ignition switch Off and On while the bike is still rolling the engine starts running again. It usually happens 2-3 times then everything is fine until the next day when the same problem occurs.
I've checked the ignition switch if there could be any contact problems but everything looks and works fine there. It's getting on my nerves already so any help or suggestion would be highly appreciated.
ORBITZ
Re: Mysterious problem
« Reply #1 on: August 19, 2010, 08:27:09 AM »
does it cut off when you slow down? or when riding ? ???
Tshu-hash
« Reply #2 on: August 19, 2010, 09:15:34 AM »
It cuts off when riding.
ORBITZ
« Reply #3 on: August 19, 2010, 11:41:48 AM »
have you checked your battery cables, maybe  one of them is loose. or your power regulator is fried....
wish i could help you better.. :-\
art
« Reply #4 on: August 19, 2010, 08:19:44 PM »
 Hey tshu welcome to the forum. I would clean and check your ignition with an electrical contact cleaner. Spray it in and work the key also replace sparkplug check that your plug cap is tight.
 How old is your scoot and miles. Some of the older scoot wires start to wear down may need to look for bear wire exposed and cover with tape. If these things don't help the coil,regulater and or stator (generater)will be the next things to check if electrical related.
 May also be a fuel supply issue chek filter and vac lines  Good luck!
« Reply #5 on: August 19, 2010, 09:04:53 PM »
also follow your wire down behide your stearing it may be bare some wear. that well make it short out.
« Reply #6 on: August 19, 2010, 09:57:25 PM »
..Welcome to th' Forum tshu-hash!
..these guys got you covered here..does sound like a loose or faulty connection...
Tshu-hash
« Reply #7 on: August 22, 2010, 01:30:09 PM »
Hello Guys,
Thank y'all for the tips. I'm gonna check all those things you've suggested. I hope it will be solved easily.
« Reply #8 on: August 22, 2010, 02:16:53 PM »
Hay just to let you know I did see somewear on line that the 07 to 09 agiltys have a recall
becuse of the shot off switch so check it out,
Tshu-hash
« Reply #9 on: August 24, 2010, 07:11:21 AM »
Well it's a '07 Agility so I will get it checked by the local dealer. Thanks for the tip!
« Reply #10 on: August 24, 2010, 10:58:18 PM »
..i thot it was just the 09s....
