When is the GV250 running hot? One of my 2009 GV's, with 16K miles on it, never goes over two bars on the temp gauge, the other, with 10K miles, will zoom up to four bars often, especially when standing still, then drop to two bars at speed. I checked the coolant, fan operation, oil level, everything seems OK. it runs fine, brakes aren't dragging. Could it be the water pump? How does one test the pump and coolant circulation.
If I didn't have two identical twin GV 250's I wouldn't worry about it but the difference between the two is dramatic. I also notice my DT300i with 3K miles on it never goes over two bars on the temp gauge.
Comments? Has anyone actually measured the coolant temperature at each bar? At how many bars on the gauge should one worry about overheating?
