Author Topic: Problems with the fuel marker  (Read 1010 times)
fabiopasche
« on: November 05, 2018, 03:17:43 PM »
Here in Brazil we are all having problems with the fuel marker. How is the measurement of you world out?
Re: Problems with the fuel marker
« Reply #1 on: November 05, 2018, 09:39:43 PM »
the gas bars go down slow  for 200 Km. after that it goes fast,  300 Km. to 340 Km. empty,  the most at 80 Kmph I got 410 Km.  riding on country roads,  no traffic,    on my downtown 300i ,
hypophthalmus
« Reply #2 on: November 05, 2018, 11:09:35 PM »
If you look at the shape of the gas tank, you'll see it's pretty irregular:
https://www.oemmotorparts.com/fiche-l/KYMCO_Downtown%20300%20i%20ABS_Fuel%20%20tank.png
Most likely there's no way for that float on the sender to actually reach the very top.
So first the fuel level needs to go down to a point where the sender will even start to register that fuel was used.
Then, the tank is wider at the top than at the base. So unless the sender goes through some kind of processing (not sure), you'll see an acceleration in how quickly the bars fall relative to the actual amount of fuel used.
mousejunks
« Reply #3 on: November 05, 2018, 11:59:20 PM »
It's never accurate. It's better to rely on distance travelled.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
« Reply #4 on: November 06, 2018, 01:17:48 AM »
Out of character in my experience. De dee said something like it does not move at all then moves fast! The two DT's I have had both would go about 85 miles before the first of the 5 bars disappeared then would go about 115 miles to leave just one bar showing. The bike would travel generally about 230 miles on a full tank before it was very, very close to flame-out. This one in Brazil goes down two bars in 10 kilometers! That tells me the sender is bad. Float, pump and arm are OK but the variable resistor of the sensor is faulty. Keep the pump but change the resistor. Use parts out of a salvage yard because the thing comes as an expensive assembly.
hypophthalmus
« Reply #5 on: November 06, 2018, 01:37:11 AM »
... that's a good catch, paying attention to the distance traveled.
fabiopasche
« Reply #6 on: November 07, 2018, 09:37:09 PM »
When I opened the topic, it was to know if in the land of you, this wrong mark happens as here. The autonomy of the bike, depends a lot on the quality of the fuel and especially how we drive it on the streets. I wanted to understand if the markers in other countries are also inaccurate  ;D
fabiopasche
« Reply #7 on: November 07, 2018, 09:38:36 PM »
So all of us will have this unpredictable mark because of the gas tank being deformed ??
fabiopasche
« Reply #8 on: November 07, 2018, 09:42:06 PM »
That's what we all do here.
I for example, when I go to fuel, I set the trip A to 00.00.
I can drive a total distance of about 350 km with a full tank to the iron pin inside the tank
When I reach the 280km mark, I drive for a gas station.
fabiopasche
« Reply #9 on: November 07, 2018, 09:45:45 PM »
This photo above is owned by a different owner. He opened the question on the Brazilian facebook of the Kymco representative in Brazil and we are talking about it.
I'll try to tell him what you told me here.
Thanks a lot for the help.
fabiopasche
« Reply #10 on: November 07, 2018, 09:47:41 PM »
I told a friend that this panel is crazy. The information is there for a quick look
