Author Topic: Venox/irregular acceleration  (Read 247 times)
B@njo
« on: November 09, 2018, 03:58:30 PM »
Hey y’all, just got a 2005 Venox that had benn sitting for 5 years. It runs but the acceleration is irregular. If I give it a little gas it will randomly take off. Is this a carb problem? Any advice is welcome. Thanks!
hypophthalmus
Re: Venox/irregular acceleration
« Reply #1 on: November 09, 2018, 05:28:11 PM »
Almost certainly a carburetor problem.
hypophthalmus
« Reply #2 on: November 09, 2018, 05:42:55 PM »
Not sure how much experience you have, or how closely you've looked at this bike but:
If you don't know the history of the bike:
I'd change the oil and filter, check the valves, change the coolant, inspect the brake fluid.
Depending on whether the air filter is paper or foam, replace or inspect/clean/oil it.
Inspect the spark plugs, check the gap.
Inspect the chain/slack. If all is good, clean it up and lubricate it.
Check the tires for wear/damage.
Lubricate the clutch cable.
None of these are very likely to be your problem, but this will get you in a good place in terms of regular maintenance.
I believe there's two carburetors on the bike. You'll need to thoroughly clean them, inspect the diaphragms for holes, verify that the slide action is correct, and sync them.
B@njo
« Reply #3 on: November 11, 2018, 02:04:09 AM »
Thanks for the advice Hypophthalmus!
