Author Topic: Cannot open Seat Compartment With key  (Read 451 times)
RussT
« on: December 01, 2018, 04:26:26 PM »
I have a Kymco 250 Excite and The Battery is dead and I cannot open the seat compartment to access the battery to charge or replace it. The key which did open the compartment with the ignition will not release the seat. Any Ideas about how to get it open? My email is ret3@mac.com
boo
get someone to sit
« Reply #1 on: December 01, 2018, 06:00:14 PM »
on the seat and try to open it. The extra weight on the seat might make the difference.
After you get the seat open, adjust the latch so it will open easier.
300GTI black
Pro 2A - member GOA & NRA
Re: Cannot open Seat Compartment With key
« Reply #2 on: December 01, 2018, 10:11:05 PM »
Boo, is the seat latch electrically operated by the key?
Otherwise ...doesn't Kymco offer a back-up seat latch lever accessed somewhere by the key? Surely?
dan v.
« Reply #3 on: December 01, 2018, 10:15:49 PM »
Can't give you definitive answer - but - often with scoots that have the seat open w/ key at the ignition switch you can access the cable at the switch.  Depends on whether you can remove enough of the front panels to gain access to the switch assy.
If you can get at it,  you may be able to be able to figure out how to pull the inner cable to release the seat latch.
If something is caught in the latch, perhaps using the key to unlock and pulling up hard on the seat will pop it open.
Good luck!
Grand Rapids, MI
Fogie
Re: get someone to sit
« Reply #4 on: December 02, 2018, 10:00:06 AM »
This!
My seat occasionally fails to open when I've got enough crap underneath to cause upward pressure on the seat itself. All I do is hold the key in the unlock position and apply downward pressure on the seat with my other hand.
2012 Kymco Frost (Yager) 200i - Toronto, Canada
Louder North
« Reply #5 on: December 03, 2018, 07:09:32 PM »
On some scoots, the Piaggio MP3 for example, you can open the trunk and there is switch you can press to open the under seat compartment.
If nothing else works, you will have to get at the other end of the cable at the ignition switch and pull on it from that end.
2009 Kymco Frost (aka Yager 200i)
10,000 km
bought used in 2018
2007 Aprilia SR50 (Morini motor)
2013 Aprilia SR50 (Piaggio motor)
1986 BMW R80
