Author Topic: Pen dropped on oil filler hole.  (Read 645 times)
PH_Looper
« on: December 08, 2018, 05:36:52 PM »
Yeah. My daughter dropped a pen on the oil filler hole and I can't see the pen on the hole. Ill try to remove the oil pan covee. Hope it works. Sigh
Re: Pen dropped on oil filler hole.
« Reply #1 on: December 08, 2018, 08:22:37 PM »
Oil pan cover on what?
scooterfan
« Reply #2 on: December 09, 2018, 03:12:50 AM »
Depending on what scoot you’ve got - I’m not sure about other models, but the 125cc models have a biggish oil drain plugs which hold the oil sieve in place. That outlet is quite close to the filler hole.
Maybe you can just drain the oil, remove that big plug, and try to hook the pen out with a piece of wire. If the filler- and drain holes on your scoot is located at the same locations as on my 125, the pen should be lying quite close to that big plug.
Louder North
« Reply #3 on: December 10, 2018, 06:28:27 PM »
Your local auto supply store should stock an extendable magnetic tool thingy should might be able to retrieve the pen without taking anything apart.
2009 Kymco Frost (aka Yager 200i)
10,000 km
bought used in 2018
2007 Aprilia SR50 (Morini motor)
2013 Aprilia SR50 (Piaggio motor)
1986 BMW R80
dan v.
« Reply #4 on: December 11, 2018, 12:20:08 PM »
How about drain the oil, then using your shop vac to suck the pen out the way it went in....
Grand Rapids, MI
Fogie
« Reply #5 on: December 11, 2018, 03:29:32 PM »
If it's a plastic pen (most are), you won't get it with a magnet. I'd grab a cheap pickle picker and fish around with that, before I started taking things apart. Here's some:
https://tinyurl.com/Pickle-Pickers
Edited to fix bad URL.
« Last Edit: December 11, 2018, 10:04:49 PM by Fogie »
2012 Kymco Frost (Yager) 200i - Toronto, Canada
« Reply #6 on: December 12, 2018, 01:39:52 AM »
Or the Red Green method:
Hang the scoot wheels up from a tree and shake the snot out of it.
Tromper
  • Seattlish
« Reply #7 on: December 14, 2018, 03:41:23 AM »
Any updates Looper?
Ya get it out of there?
2008 SYM HD200 "Niwanibiz"
k9 S200 (Blue) "Max" (Sold)
