Did you miss your
activation email
Scooters - 125 to 300
Agility 125
Rear brake
Topic: Rear brake (Read 657 times)
Footsoldier2008
Newbie
Rear brake
December 09, 2018, 11:23:04 AM »
Would I have to take all the panels off to change the rear brake cable?
Newbie
Re: Rear brake
December 09, 2018, 07:34:01 PM »
You should get away with only taking the headlight panel off and you should be able to feed the new one through as you pull the old one out. Also remove the seat bucket as there is a clamp on top of the transmission above the variator.
Footsoldier2008
Newbie
Re: Rear brake
December 10, 2018, 05:00:24 PM »
Cheers mate
Back
