Author Topic: Did I Damage My Engine?  (Read 427 times)
Togger
« on: December 14, 2018, 09:44:43 PM »
A few weeks ago I reported that my Bet&Win 250 made a slight metallic ticking sound, but it disappeared and I rode it for about an hour. Seemed ok though. Now I realise that the oil was low for some reason even though I changed it a couple months back and it was full at the time. I can't understand why it dropped so quickly in maybe ten uses. Now I can't get the scooter started at all, the starter just grinds but the engine won't turn over. Have I damaged the engine. The dipstick showed very little oil when I checked it.
Re: Did I Damage My Engine?
« Reply #1 on: December 15, 2018, 01:13:49 AM »
 :'( :'( :'(with very low oil , and running it for a few hours ,  does not look good !!!  could be any thing from the piston, to the valves, if it wont start taking engine apart would be the way to go,.  or  part it out and get a new ride,
« Reply #2 on: December 15, 2018, 04:43:09 AM »
"Won't turn over"....please clarify. Do you simply mean the engine won't start?
 Or, you get no indication or sound that the engine is turning?
It seems that 'some' oil showing on the dipstick might not mean a destroyed engine.
If the engine is showing signs of a dead or dieing battery - I'd look there first for the reason of a no start.
Louder North
« Reply #3 on: December 17, 2018, 06:39:11 PM »
Stig is right - need to clarify if 'won't turn over' means  'is it seized or not?'.  Could try putting a bit of oil in the cylinder through the spark plug hole and try turning it over with a wrench on the crankshaft (on the shaft the variator is attached to).
2009 Kymco Frost (aka Yager 200i)
10,000 km
bought used in 2018
2007 Aprilia SR50 (Morini motor)
2013 Aprilia SR50 (Piaggio motor)
1986 BMW R80
Viper254
  • Moped Pirate
« Reply #4 on: December 19, 2018, 09:47:48 AM »
To be honest this isn't sounding great. Check your oil regularly, boys and girls.
*Sweats in the background about how much is in the car*
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
