Author Topic: 2012 Like 200i: Swap push button release for lockset?  (Read 1057 times)
IAATM
« on: December 16, 2018, 07:40:35 PM »
Is it possible to replace the existing front fender storage box lock set (P/N 75581) on my Like 200i with a push-button release? While I appreciate that a lot of folks like the storage box's locking feature, I'd personally like to throw my phone, garage door opener, and house keys in there, and be able to access them while the engine is running - which I can't do now, because I'm forced to turn off the ignition and use the key to open the storage box.
Is it possible to remove the lock-set without doing damage to the plastic door?
If so, is there another model of Kymco that uses a push-button, instead of the lock?  If so, perhaps I could order that push-button part and swap the two pieces?
Thanks!
David E
Re: 2012 Like 200i: Swap push button release for lockset?
« Reply #1 on: December 16, 2018, 07:43:02 PM »
Now this would be ideal.
« Reply #2 on: December 17, 2018, 01:18:24 AM »
Years ago a member addressed this problem by making a spare key, cutting it down, rubberized the head, and leaving it in that latch.
Seems like you better not ever forget to take it along when parked in public!
I don't know that many step through scooters permit access to that box without some action taken by the key.
IAATM
IAATM
« Reply #4 on: January 07, 2019, 07:30:23 PM »
or better yet this one from Amazon?
Prime Products 18-3060 5/8" Thumb Operated Lock with Straight and Offset Cam
Viper254
  • Moped Pirate
« Reply #5 on: January 08, 2019, 08:14:28 AM »
Looks possible, but the measurements would have to be spot on.
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
IAATM
« Reply #6 on: January 12, 2019, 02:01:10 AM »
Turns out we need the longer model, which is available on Amazon for about $10 USD, plus some rubber washers:
JR Products 00145 1 3/8" Thumb Compartment Lock
Model: 00145
IAATM
« Reply #7 on: January 12, 2019, 02:11:29 AM »
photo 1/2
IAATM
« Reply #8 on: January 12, 2019, 02:12:22 AM »
photo 2/2
David E
« Reply #9 on: January 12, 2019, 02:25:14 AM »
That came out nicely.
sailorman
« Reply #10 on: January 25, 2019, 10:46:07 PM »
I bought/installed the 1 3/8" model.  Required a couple of extra stainless washers and grommets, easily found at local Ace.  Installed and it works!
Honda CB350 (Ret.)
Honda Metropolitan
Kymco 200i
IAATM
« Reply #11 on: January 26, 2019, 01:15:51 AM »
That's great!  How about a photo?  :)
sailorman
« Reply #12 on: January 26, 2019, 09:38:16 PM »
Looks just like your installation!
Honda CB350 (Ret.)
Honda Metropolitan
Kymco 200i
