Author Topic: Battery discharging..  (Read 2001 times)
guile
« on: December 18, 2018, 08:10:18 AM »
The battery of my X (2006) is discharging in less than 2 days. I changed the battery a couple of times.
What could this problem be other than a bad battery?
Re: Battery discharging..
« Reply #1 on: December 18, 2018, 02:41:37 PM »
Bad stator or failed regulator-rectifier.
xsel777
« Reply #2 on: December 18, 2018, 03:40:56 PM »
You said in your original post, "I CHANGED the battery a couple of times". This means several batteries, so they can't all be bad. Therefore it must be another problem, like suggested by CROSSBOLT.
I would think that the battery light should be on if the stator or regulator totally failed,but if just partially (on their way out condition) faulty, then the battery might stop be getting a charge but not enough.
You need to get out the mulitimeter, and start checking what voltage you are getting at the battery at idle, and when revving.
That is as far as my knowledge goes.
« Last Edit: December 18, 2018, 03:45:50 PM by xsel777 »
scooterfan
« Reply #3 on: December 18, 2018, 04:43:17 PM »
It will make sense to remove the battery and to charge the battery with a battery charger untill the battery is fully charged. Then you need to take the battery to a battery dealer to do a proper load test on the battery. The battery dealer will tell you whether the battery is faulty or not.
It is important to know that a load test can not be done on a battery if the battery is not fully charged. Therefore it will be better if you get the battery charged before you visit the battery dealer.
The first thing you actually need to do after the battery passed a load test, is to find out whether the battery gets charged when the engine is running:
If the battery is not charging you can do a test on the voltage regulator / rectifier:
If the voltage regulator / rectifier is not faulty you can do a test on the stator :
I hope this helps.
« Last Edit: December 18, 2018, 04:52:57 PM by scooterfan »
guile
« Reply #4 on: December 18, 2018, 07:00:35 PM »
Thanks all, will get tot it!
sissymary
« Reply #5 on: December 24, 2018, 04:30:12 PM »
Probably the stator? But is your seat closed? If not, the light stays on and will kill the battery real quick.  :-*
« Reply #6 on: December 24, 2018, 08:32:49 PM »
Great videos, Scooterfan! Sissy brings up a real good one about the seat light! Dint think of that but would kill the battery, definitely!
I checked mine. Had to have the wife help 'cause I could not close the seat with me inna tub! Har, har!
sissymary
« Reply #7 on: January 07, 2019, 03:19:21 PM »
I unplugged my under seat light after about the 3rd time my battery went dead. You can close seat, pull up on it to make sure it is all the way down and locked, and a latch can/will still let loose on one side, and the light will come on and kill the battery. Carry an LED flash light and unplug light. Not worth it. :-*
guile
« Reply #8 on: February 01, 2019, 02:32:45 PM »
It was the rectifier. Changed it for a € 18,- universal one and all works fine; the battery doesn't discharge anymore.
« Reply #9 on: February 01, 2019, 03:30:36 PM »
That is great to hear! £18 does not sound too bad, what'that, about $30US? Universal means china?
guile
« Reply #10 on: February 01, 2019, 03:32:52 PM »
18 euros is about 20 us
Yes, Chinese (probably)
« Reply #11 on: February 01, 2019, 03:50:04 PM »
Oops! € is euros, £ = pounds sterling! Oops!
