Author Topic: Kymco 300i grinding clutch sound  (Read 1169 times)
Megahed77
« on: December 23, 2018, 05:35:19 PM »
Hello im new to this forum , i was wondering i bought a kymco 300i 2014 used it has 17k km on the clock ,I dont know how to describe the sound but there is a strange sound that comes randomly from the clutch area whenever I accelerate its like grinding metal or when you keep the sidestand on the floor and move with it , it comes and goes randomly , ive had the clutch pads, belt , rollers changed but the sound didnt go away.
Re: Kymco 300i grinding clutch sound
« Reply #1 on: December 24, 2018, 02:11:18 AM »
Check the oil in the gearbox.
kneeslider
« Reply #2 on: December 24, 2018, 08:29:04 AM »
You have to open it all up and have a lopk inside, check for signs of metal to metal contact.
Sent from my HUAWEI VNS-L31 using Tapatalk
2019 Yamaha X-Max 250
Megahed77
« Reply #3 on: December 24, 2018, 10:43:08 AM »
I’ve changed both oils engine and gearbox according to the recommended viscosities in the service manual still there is that sound thing is , it comes and goes randomly especially when accelerating quickly
Megahed77
« Reply #4 on: December 24, 2018, 10:44:28 AM »
Any idea what could cause that ? And where to look for ?
kneeslider
« Reply #5 on: December 24, 2018, 01:57:24 PM »
You'll have to take it to a workshop for them to open it up.
Megahed77
« Reply #6 on: December 24, 2018, 07:33:50 PM »
I’ve already changed it according to the service manual but the sound still appears
« Reply #7 on: December 24, 2018, 07:53:08 PM »
I would check the washers, - they are different thicknesses , on the driving  pulley,  you may have one in the wrong place,  and would cause some-thing to rub together,  you are reading in Km.s  , are you in Canada ottawa area,  can help if you are,
« Reply #8 on: December 24, 2018, 08:07:44 PM »
1. How much oil came out when you changed it?
2. How much oil did you put back in? What kind/weight oil did you put back in?
3. What did the old oil look like?
That is the nature of what I was asking...
Megahed77
« Reply #9 on: December 24, 2018, 09:32:47 PM »
A little less than what is supposed to come out it looked a bit blackish probably burnt  ive put 0.23L in it SAE 80w-90 oil
Megahed77
« Reply #10 on: December 24, 2018, 09:36:50 PM »
Nope I’m not unfortunately im from Egypt , do you mean the rollers ? Ive changed those too , this makes sense as i placed them myself ill check on them again , eventhough i made sure ive placed them right hopefully its something not that serious
« Reply #11 on: December 25, 2018, 12:31:24 AM »
That's what I was looking too see! Good show. Probably not the gears, then. I think de dee is on the right track. There usually two washers up front that have a bevel on the inside which should face a radius on the shaft coming out of the engine. It also is critical to have as much slack in the belt when the front pulley halves are assembled and the shaft nut tightened.
« Reply #12 on: December 25, 2018, 08:36:16 PM »
put some grease on shaft,  and flat washer , install pulley and boss install belt ,install outer pulley ,and install bevaled washer cupped to inside,  and last nut with lock tite blue on threads, last check bearing in outer cover it may be the problem all along
