Author Topic: help with side stand!!!  (Read 1308 times)
HTCneil
« on: August 30, 2010, 08:13:27 PM »
my side stand is loose, what i mean is that i lift it and it falls almost half way down and shuts off the ignition. How do i fix this?
art
Re: help with side stand!!!
« Reply #1 on: August 30, 2010, 09:18:50 PM »
 Probably lost the spring take a good look at it. May just need to re attach or find a replacement. Just remove it or zip tie it  up if you have to order one. Personaly I don't ever use the side stand but those 500's are a bit heavy.
« Reply #2 on: August 31, 2010, 01:04:42 AM »
..take a look at the fasteners, and yeah, the spring....not a safe condition to have a saggy kick-stand....
..remove it and bypass the switch if necessary...
TechGuy
« Reply #3 on: August 31, 2010, 05:50:33 AM »
Get it fixed,  wire it up or take it off.  Riding with a sagging side stand could be dangerous.  Sounds like you are missing a spring.
You might step down on that side and catch the loop with you pant leg and off you go.
It could also dig in during a turn.
Serious.
