Author Topic: Mongoose 90(Brand New) won't idle when warm  (Read 2739 times)
Goose94405
« on: December 26, 2018, 08:41:17 PM »
So my wife convinced me to get the mongoose 90 for my daughter because of the reverse option(something the other quads that size in my area lacked). It ran great for about 5 minutes around the yard then it died. It seemed like a carb issue to me. I turned a 'idle screw?' clockwise and that only increases the rpms a bit but doesn't help keep it running really. I can run it around the yard all morning under mid to heavy throttle. (the dealer is naturally closed the week of Christmas)
any tips/tricks to get it working properly. My wife won't let me monkey with it until she see's some proof of the issue and I want to watch my daughter rip up and down the roads without the quad dying when she is stopped.
Thanks,
E
AK90Mongoose
Re: Mongoose 90(Brand New) won't idle when warm
« Reply #1 on: January 22, 2019, 07:23:23 PM »
Were you able to figure anything out on this issue? I am having the same problem as you and its supper frustrating.
« Reply #2 on: January 23, 2019, 02:19:53 PM »
These are new, right? Sounds like a warranty issue. Also sounds like the dealer had these sitting around a long time with gas in them and the idle jet got plugged. Me, I would take the carb off and ckeck/clean the jets to start but that could void your warranty unless you can leave no traces of your work!
