Author Topic: Super 8 jet change  (Read 2011 times)
themearnsy
Super 8 jet change
« on: January 05, 2019, 04:15:04 PM »
Hi I want to change the carb jet on my sons bike, is there any drawings showing the jets location and do I need to take the carb off ?
tortoise
Re: Super 8 jet change
« Reply #1 on: January 05, 2019, 08:21:59 PM »
eamartin
« Reply #2 on: January 06, 2019, 02:48:01 AM »
You  will need to drain the gas from the float bowl, remove the carb,, and remove the float bowl from the carb to access the jets.  Why do you want to change a jet?
themearnsy
« Reply #3 on: January 07, 2019, 01:36:31 PM »
eamartin
« Reply #4 on: January 07, 2019, 01:54:53 PM »
thanks its a 2 stroke.
Same reply whether it's a 2T or a 4T : You  will need to drain the gas from the float bowl, remove the carb,, and remove the float bowl from the carb to access the jets.  Why do you want to change a jet?
themearnsy
« Reply #5 on: January 10, 2019, 10:39:22 AM »
to get some more power.  I have changed the variator rollers to 7g ones, that has improved things (the ones removed also had massive flat spots!)
Thinking of a Leovince TT exhaust unless  you can recommend anything else.
Hejust wants to go faster!
agoncalvesjr89
« Reply #6 on: October 15, 2019, 01:30:21 PM »
Just get the new exhaust , that sh** will spike the Super 8's performance Heavy , like double the torque from stock exhaust  - and jet it to about 86-88 with the new exhaust.   Exhaust and jetting is huge ,,, maybe throw some  gram Sliders in their.
For jetting , just unscrew and remove airbox first -- then take off Throttle carb cap , gas line , and unbolt the carb. Once unbolted disconnect the e choke --- Flip carb upside down - unbolt bowl.. Maine jet is the one sitting higher  , closer to your face , unscrew it and put in a fatter one. 86-88 for expansion exhaust -- Keep air filter on bike.     JEts to use are 4mm keihin round jets .... stock part # 99101-116 - Jets size # .
2013 SUPER8 2T 50
70cc MALOSSI KIT
STOCK CARB MAIN JET AT 98 , STOCK AIR BOX SNORKEL REMOVED.
NARAKU VARIATOR 6 GRAMS SLIDER / ROLLER COMB.
TECNIGAS NEXT R EXHAUST
SLIGHTLY LONGER THAN STOCK GATES DRIVE BELT.
TOP SPEED 50ISH , TONS OF POWER. 45MPH CRUISING
