Author Topic: CR7EIX vs. CR7HIX  (Read 2054 times)
sailorman
CR7EIX vs. CR7HIX
« on: February 03, 2019, 02:43:43 PM »
Think I just installed the wrong plug on 2012 200i . . . installed NGK CR7EIX . . . . but on reflection, it looked significantly longer in the thread area than the stock OEM plug.  Do I need to replace this with CR7HIX?  Or am I safe?  Do not want to restart engine before being sure . . . but do not want to have to redo the job if not necessary. . . .
Honda CB350 (Ret.)
Honda Metropolitan
Kymco 200i
Re: CR7EIX vs. CR7HIX
« Reply #1 on: February 03, 2019, 03:30:28 PM »
Yes, do not start your engine with the CR7EIX in the LIKE200i.
I have no idea what will happen. Maybe nothing....
Years ago I investigated which Iridium Denso and NGK was a direct replacement for the normal plug.
My studies showed that the CR7HIX was the correct plug - and I have been using it in my LIKE200i for 6 years with good results.
BTW - found the NGK Iridium to work better than the Denso Iridium - so took the Denso back out. Again - I forget why I preferred the NGK.....6 years ago.
The used EIX plug seen here was used in another scooter (Forza or Burgman - forget which)
« Last Edit: February 03, 2019, 03:34:27 PM by Stig »
sailorman
« Reply #2 on: February 09, 2019, 02:25:22 AM »
Thanks for the clairification Stig. I did not start engine with EIX in it. Got an HIX instead, installed, gapped valves, changed oil, gear oil, and took it out on the road. All is good.  I will wait on changing the tires until these have some wear on them.  But if they are "hard" tires, I am thinking of running them with -5 PSI for a somewhat softer ride and more contact with road.  ??
Honda CB350 (Ret.)
Honda Metropolitan
Kymco 200i
« Reply #3 on: February 09, 2019, 03:43:42 AM »
Dropping 5 lbs will affect the tires intended behavior and handling, esp. in the front.
Perhaps softer rear shock setting will help the ride.....but scooters , especially those with12" wheels have a pretty lousy ride over rough stuff by nature....save perhaps on a Vespa.
Pick smoother routes, and/or slow down!
The Kenda tire compound is long wearingly hard - not sure the tire compresses much differently than a Michelin.
Probably best to run close to manual specs for safety.....
sailorman
« Reply #4 on: February 11, 2019, 09:07:17 PM »
Sounds good, thanks!
I don't feel any difference I can put my finger on between the OEM and HIX plugs. But if it lasts longer, that will be a net gain as I do not like taking the plug out and putting it back in. Always afraid I will drop it down that cooling shroud!  Plan to just loosen it and then retighten it whenever I have seat off for something else, just to make sure threads do not bind.
Honda CB350 (Ret.)
Honda Metropolitan
Kymco 200i
« Reply #5 on: February 12, 2019, 01:20:54 AM »
NGK tells me the chrome on the threads prevents seizing. No anti seize paste needed. Retorqeing plug risks overtightening.
This is only my take on this.....
Viper254
  • Moped Pirate
« Reply #6 on: February 12, 2019, 09:09:48 AM »
Has anybody actually ever had a plug seize? Don't think that's a problem I've actually ever had!
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
« Reply #7 on: February 12, 2019, 05:36:00 PM »
Not me BUT have had to use a cheater pipe on a breaker bar to get plugs out of both cast iron and aluminum heads. All the threads stayed in the heads but heard stories....used silver anti-seize since 1956.
« Reply #8 on: February 12, 2019, 08:44:28 PM »
Yeah, in Massachusetts had one plug frozen in our '67 289 Mustang convertible. This was about 1973 or 4 - so likely had been in there for 6 or 7 years.
Split open two sockets trying to remove it - (these were tools borrowed form a mechanic at a nearby Gulf service station) -- then just changed the others and left it in there!
Loved that car - commuted all winter from Amherst to Springfield Hosp. with the top down on I-91. At speed, snow goes right on over!
« Reply #9 on: February 12, 2019, 08:55:51 PM »
 8)
