Author Topic: installing stock LIKE200i exhaust  (Read 474 times)
« on: February 03, 2019, 05:17:27 PM »
Re-hanging the heavy/awkward exhaust can be a bit of fun.
I tied the muffler up, so it can move about - while using a mirror to  line up and hand thread in the nuts on the engine studs.
Taking the weight off of you is a help - while you get things connected under there.
Everything is loose until all fittings are in place - then tighten. GENTLE with those stud nuts! - it is possible to strip stud from engine head!
BTW- I disconnect the distant end of the oxygen sensor wire, and leave the O2 sensor fitted to the exhaust pipe (it case it is seized)
« Last Edit: February 03, 2019, 05:20:34 PM by Stig »
tortoise
Re: installing stock LIKE200i exhaust
« Reply #1 on: February 03, 2019, 10:00:00 PM »
Context . . just curious why the exhaust was removed?
« Reply #2 on: February 03, 2019, 11:29:01 PM »
Removing rear wheel for a new tire.
Some feel it is necessary also when bleeding rear brake, or replacing rear pads -- but I've found that removing exhaust is not actually required.
(Vespbretta and I both did a DIY on removal of rear wheel.)
Getting exhaust off is much easier than the reverse.
LidoCA
  • I LIKE chinese plastic.
« Reply #3 on: February 04, 2019, 10:46:06 PM »
I think I used my feet to hold up the muffler while sitting/ lying on the garage floor. I recommend the Stigs way of doing it.
Steve
2013 LIKE 200i LX.
2016 Yamaha SMax
2014 Yamaha Majesty
La Mirada, Ca.
