Author Topic: 2016 kymco 450i Uxv shiftting issues  (Read 241 times)
Whiskeybottombrewing
« on: February 04, 2019, 04:00:53 AM »
I have a 2016 450i Uxv with a plow. I was out using it the other day and after the first pass I went to shift from reverse back to high gear and the shifter just went loose. I struggled with it in -25 below zero and then finally figured I can just shift it by moving the shifting rod from the engine under the seat to put it into high gear so I could put it back in my garage. I still have to have the shifter in the right gear on the dash if I want to change the gear below. When In high gear I can actually put it reverse wit the shifter but it won’t go back into high unless I do it by hand below. Has Anyone else that has had this problem? How can I get it fixed with out bringin it in?Ok
