Author Topic: YUASA chart if you want more battery power  (Read 259 times)
« on: February 16, 2019, 04:09:31 PM »
These pages help you find a more powerful battery of the same, or nearly the same, physical size as your stock battery.
I used it to increase the cold cranking amps over the supplied stock batteries in two scooters.
I measured my stock battery - noted the terminal posts location and type - then matched one with more power.
https://www.yuasabatteries.com/wp-content/uploads/2017/12/Yuasa-Battery-Application-Guide-2019.x78244.pdf
Re: YUASA chart if you want more battery power
« Reply #1 on: February 16, 2019, 07:40:33 PM »
No Likes on their list.....
« Reply #2 on: February 16, 2019, 10:33:53 PM »
Sorry, should have mentioned....
No nothing on their list !! --- use your measurements to pick your battery from the charts.
Needn't remove your battery....just view it and measure top, then stick something down the side to get that measurement.
