Author Topic: Oil leakage  (Read 443 times)
Dsoul82
Oil leakage
« on: February 19, 2019, 06:48:01 PM »
Hello,
What is this black part? I have some oil leakage on the plug on this?
https://imgur.com/a/0JnPWVB
thanks!
BR
Re: Oil leakage
« Reply #1 on: February 19, 2019, 09:37:59 PM »
that is the oil pan inside is the water pump oil pump and stator,  buy the gasket and some liquid gasket smeer it on the gasket   I did both sides,  torque the small bolts , they break easy,  Oh you buy two small O rings for in side you will see them when it is open,  they are easy to mash,   good luck with the job,  de dee
Re: Oil leakage
« Reply #2 on: February 20, 2019, 02:19:43 PM »
If your picture points to the large, round (about 1.25 inches diameter) cap with a screw slot in the center of a 4 inch diameter, round cover, that takes an o-ring. Real easy to fix.
