Author Topic: Coolant for 450i  (Read 1094 times)
DaveTJ321
Coolant for 450i
« on: March 23, 2019, 05:15:51 AM »
Hello, the coolant in my 450i is just above the low level.  Is there any specific type/brand I need to add to what's already in there?  Is any prediluted 50/50 mix ok?
airshot
Re: Coolant for 450i
« Reply #1 on: March 23, 2019, 02:21:39 PM »
As long as it is green your good, stay away from the pink dexcool. They may have taken the pink off the market due to its issues.  You can just by the 50/50 premix if that is easier.  If you mix your own, be sure to mix with distilled water....do NOT use tap or well water.  To many minerals and chemicals, that can clog your system.
