Author Topic: Xciting 250 Water Pump Mechanical Seal & Seal Washer  (Read 2670 times)
SVX_Blue
« on: March 28, 2019, 06:27:15 PM »
So I just got done replacing the stator in my X250. Cleaned up the right crank case cover, put it on, filled it with oil,put most of the bike back together.
FYI if anyone has this scooter - Kymco discontinued the right crank case cover gasket.
Time to refill the coolant... and now it is leaking coolant from the weep-hole just under the wp housing.
Because I bought a non-running scoot I expected stuff like this. The mechanical seal was probably bad after the scooter sitting so long and with me cleaning all the grease/oil/dirt off the crank case cover it probably unplugged/unclogged the weep hole.
So now on to my question: The service manual says that "when you replace the mechanical seal, a new seal washer must be installed to the impeller." I have the part number for the mechanical seal but not that porcelain seal washer. It isn't even on any parts diagram I've been able to look at. Does anyone have the part number for this - or should I just chance it an use the one already installed?
Small CC TEK
Re: Xciting 250 Water Pump Mechanical Seal & Seal Washer
« Reply #1 on: March 29, 2019, 11:11:43 PM »
Sorry just noticed the pics all wild looking
Sent from my SM-N920T using Tapatalk
