Author Topic: Kymco Yager 200 Roller spec's  (Read 4913 times)
Re: Kymco Yager 200 Roller spec's
« Reply #15 on: July 11, 2020, 01:57:57 AM »
yager 200 the variator pulley is 5 1/16 "  the downtown 300 variator is  5 13/ 16 " this is the diameter of each pulley
Louder North
« Reply #16 on: August 24, 2021, 06:20:26 PM »
Best thing you can do for a Yager. Get one of these:
https://scooterpartsco.com/kymco/kymco-yager-200/malossi-variator-for-kymco-and-sym-scooters?zenid=e345232f79d5076a72cd1c216f5754e9
Comes with 2 sets of rollers 9.5 and 13.5 gr., both are way too light for normal street riding. I ordered 17 gr. which for me were just right. I've tested both stock and 3 different weight Malossi's on my secret dyno test facility. Acceleration numbers for 1/8th mile are:
stock ......13.14 sec. @ 6412 rpm
Malossi W/9.5 gr.....12.20 @ 8740
            W/13.5 gr......12.26 @ 7921
            W/17 gr. .....12.63 @ 7243
The Malossi with 17gr. rollers yields a solid 1/2 second improvement in 1/8th mile times.
Stock rollers are a odd size, 20.8 dia x 15 wide at 17.5 gr.
Thanks.  Good advice.  I just installed the Malossi multivar, belt and clutch. In the variator I used a combination of the two roller weights as, according to the leaflet that came with the variator, a 175 cc scoot falls in between their recommendations for the 9.5 gm and 13.5 gm rollers.  See photo attached.
2009 Kymco Frost (aka Yager 200i)
10,000 km
bought used in 2018
2007 Aprilia SR50 (Morini motor)
2013 Aprilia SR50 (Piaggio motor)
1986 BMW R80
