Author Topic: I can't find Cylinder Head for 2009 Kymco Super 8 150cc 4T  (Read 1382 times)
polishpipes10
  • mgtapGD
« on: April 24, 2019, 12:43:09 AM »
Hello,
If anyone out there knows of a place I can get a replacement cylinder head or recommend an alternative I would Greatly appreciate it. I have spent 2 weeks of wasted time I'll never get back searching for this part. I ordered 2 so far neither of which fit my engine. Please help or suggest other options if you know.
Kymco Super 8 150cc 4T 2009
Thank you
KymcoRockr
Re: I can't find Cylinder Head for 2009 Kymco Super 8 150cc 4T
« Reply #1 on: April 25, 2019, 09:40:31 PM »
What problem are you running into with the ones you have ordered? How are they not fitting?
AK550
Yager 200
hyracer
« Reply #2 on: May 19, 2020, 03:24:32 PM »
After installing a big bore kit (170CC) I also tried to replaced the stock head with a big valve head. It appears the KYMCO 150 uses a taller head than most heads on a GY6 engine. That places the camshaft further out from the crank. To use the aftermarket head I would have to remove a number of links from the camshaft chain.
I also found that the base circle on the stock KYMCO cam is larger than aftermarket performance cams. With the aftermarket performance cam in place, there was not enough adjustment on the stock rocker arms to even come close to setting valve lash.
So at this point I have a large valve head and cam that won't do me any good.
souzamoto
« Reply #3 on: May 19, 2020, 06:41:49 PM »
Your looking for a stock head?
If so, try a Kymco dealer.
Tromper
  • Seattlish
« Reply #4 on: May 20, 2020, 12:04:24 AM »
Saw a few sites showing an OEM available but on backorder.
2008 SYM HD200 "Niwanibiz"
k9 S200 (Blue) "Max" (Sold)
