Did you miss your
activation email
Technical | How To
Grand dink 125s starter keeps running without ignition on?
Topic: Grand dink 125s starter keeps running without ignition on? (Read 212 times)
Kevin newbie
Newbie
April 28, 2019, 04:48:39 PM »
Hi all, my wife has a a grand dink 125s and the starter motor stays on even when the ignition is switched off. Any ideas.
Thanks. Kevin.
West Tennessee, USA
Re: Grand dink 125s starter keeps running without ignition on?
April 28, 2019, 07:29:43 PM »
Starter relay/solenoid welded closed. Probable cause is a poor battery. Fix is to replace the solenoid and load test battery. Replace battery if load test fails.
Back
