Author Topic: 2009 Agility 50 problems with starting / idling  (Read 1410 times)
shawn2nd
« on: May 03, 2019, 07:40:09 PM »
I just bought a 2009 Kymco Agility 50 ONE with about 6500KM on it. On my test ride before I bought it, it fired up with out issue (maybe it was already warm) but since owning it I've been running into issues with starting / idling. Long story short, I've gotta simultaneously give it gas when starting it, when I start it without any throttle, it won't start. When idling at lights, I'm constantly throttling it, because if I don't it will die.
I just got it back from the shop, all the fluids changed out, carb basic cleaning received, valve clearance checked, and spark plug replaced. When I took it home ran fine, maybe because the guys at the shop had done a test ride before I got there and it was warm already. But now same issues...only difference is that now when idling, sometimes the revs kick up, where I can feel the scooter pushing a bit. If I throttle it a bit, the revs go back down, and the it putters out and dies.
It is pretty annoying to continusouly have to juggle the throlttle at any red light. Any suggestions? I took it to a Triumph dealer, as I don't have a Kymco dealer immediately near by, and the only scooter specific shops cater to Vespas only. I am hesitant to take it back to Triumph, as maybe they're not too specialized on scooters? Idk.
woyciesjes
Re: 2009 Agility 50 problems with starting / idling
« Reply #1 on: May 05, 2019, 02:18:52 PM »
Did they check the automatic choke? What about adjusting the idle screw? Sounds like something I've been running in to (except I have about 12,500 miles)...
Maybe a new carb, $30...
https://www.monsterscooterparts.com/scooterparts/street-brands/kymco/kymcoagility50/19-mm-carburetor-with-electric-choke-for-kymco-agility-50-50cc-scooter.html
I just put it in mine yesterday. Quick test run it seems okay.... we'll see as the week goes.
2014 Agility 50 4T
Still stock after all these years...
Except for a 19mm carb now.
Phillipcooke11
« Reply #2 on: May 31, 2019, 10:58:32 PM »
I found a crack along the plastic manifold  just where the carburetor joins it  and had same problem. Worth a look. 12 uk pound to get new one. Hopefully this helps.
jesseg010
« Reply #3 on: June 02, 2019, 11:48:25 PM »
yup i would give a good guess that the choke/ air flow could be the issue. check your hoses
