Author Topic: 72. Cc up grade  (Read 493 times)
Phillipcooke11
72. Cc up grade
« on: May 05, 2019, 02:19:46 PM »
Hi everyone. I have bought a new 72 cc upgrade kit for my  Kimco agility 50 4t. Are the much better than standard 50.cc  I am 53 years old and 95 kilos weight.  My  kimco goes 70 kph on level roads but really slow on hills. Race variator fitted and 8 grm weights. 19 mm carburetor standard kimco exhaust   and jetting 84..  Thank you.
eamartin
Re: 72. Cc up grade
« Reply #1 on: May 05, 2019, 04:02:35 PM »
Which brand 72cc did you buy?
Phillipcooke11
Re: 72. Cc up grade
« Reply #2 on: May 06, 2019, 12:31:08 AM »
A Chinese brand rated at 80 cc I look at dimensions and is 72 cc. Hope you can help. Please
Viper254
  • Moped Pirate
Re: 72. Cc up grade
« Reply #3 on: May 06, 2019, 10:25:12 AM »
Hi,
Good choice on the 72cc kit. It doesn't put too much strain on other engine components.
If the kit is worth it's salt, it should come with a main jet for you to replace your current one with. You're unlikely to gain any top speed, but hopefully it will have a little better torque on the hills as you say :)
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
Phillipcooke11
Re: 72. Cc up grade
« Reply #4 on: May 21, 2019, 12:20:32 AM »
Many thanks for info Viper 70cc  up grade. Here all gaskets   no jet upgrade. Got new exhaust gasket separately. Before I go on.. The bike is 2005,, standard power 49cc. 4t. Standard exhaust. Standard carb. Jet 84. Top speed on flat road over 100 miles. 70kph. As o ride from England to Wales. 50 miles away every week end. Mods are only race variator. And i have used new jmc 6.2 gm weight. Fantastic combo. I highly recommend. Still hits top speed and revs high on hills . Miles is 26 thousand miles on this bike... Kimco good scooter. Looking forward to seeing your thoughts. Thanks
