Author Topic: Sidelight-Led/SMD Led change  (Read 421 times)
Szpilu
« on: May 20, 2019, 08:08:24 AM »
Dear All, somehow can I change the front sidelight smd-leds?on the left side two smd leds doesn't work.
2011 Downtown 300i white/black
Szpilu
Re: Sidelight-Led/SMD Led change
« Reply #1 on: July 09, 2019, 12:36:27 PM »
Okay, I did it last week. Unfortunately You must heat the headlamp in an oven with ten minutes on 100 °C, then You can easily disassembly the  lampshade then you see the led side light, 3 bolts hold the pcb, then you can soldering the smd. These smd are 4 pins. The common three points the positive side,and the one negative side.
