Author Topic: More Speed after 72cc install? 2015 Super8 4T  (Read 3746 times)
AylmerFreerider
« on: May 20, 2019, 01:21:12 PM »
Hey all trying to figure out why I can't get a solid 70-75 km/h out of my 2015 Super8 4T.  I seem stuck at 65km/h
I have done the following
72cc BBK
Polini Hi-Speed Variator w/ 6.5 weights
1000RPM Contra Spring (was a 750 stock) - Looking to go to the 2000 RPM spring with the new power from the 72cc BBK
Technigas Silent exhaust installed.
derestricted CDi (removed purple wire)
2015 Super 8 50R
72cc BBK
Polini Hi-Speed with stock boss and 6.5gr rollers
Naruko 1000RPM White Spring
Technigas Silent Pro Exhaust
3 x 1" Air Filter additions to Air Box
eamartin
Re: More Speed after 72cc install? 2015 Super8 4T
« Reply #1 on: May 20, 2019, 02:37:33 PM »
What is your carburetor set-up?
tortoise
« Reply #2 on: May 20, 2019, 03:52:15 PM »
Big bore kits offer more torque for hills and headwinds, but the drive pulley ratio remains the same relative to crankshaft revolutions . . unless rear gears are changed.
Unbalanced rotational dynamics also enhance the odds of crankshaft and connecting rod bearing failure.  Pretty much a lose/lose situation!
For others researching . . initially select a scooter model with an engine size suitable for your speed expectations, and keep it stock!
« Last Edit: May 20, 2019, 03:55:31 PM by tortoise »
AylmerFreerider
« Reply #3 on: May 20, 2019, 04:30:03 PM »
I upped the main jet to a 92 from an 82 (10% ish for the BBK)
2015 Super 8 50R
72cc BBK
AylmerFreerider
« Reply #4 on: May 20, 2019, 04:32:18 PM »
I have read many different things and most say that the bottom of the motor is pretty much the same from 50cc-125cc.
I wasn't looking for great speed gains 5-10km/h  I am not looking at turning my scooter into a hotrod just a safe rod.
2015 Super 8 50R
72cc BBK
eamartin
« Reply #5 on: May 20, 2019, 10:47:02 PM »
72cc BBK
What is your air filter set-up?
eamartin
« Reply #6 on: May 20, 2019, 11:20:22 PM »
Also,  what was your top speed on level ground before any modifications?
AylmerFreerider
« Reply #7 on: May 22, 2019, 03:17:48 PM »
Air filter is the same (mechanic said he expanded the opening only)
My top speed before was 65km/h on the flat
2015 Super 8 50R
72cc BBK
eamartin
« Reply #8 on: May 22, 2019, 06:51:59 PM »
allHey  trying to figure out why I can't get a solid 70-75 km/h out of my 2015 Super8 4T.  I seem  stuckat 65k
You don't seem to have improved your top speed at all.  Is that correct?  Did you do upgrades incrementally or all at one time?  Oh...did you ever install the smooth boss bushing?
AylmerFreerider
« Reply #9 on: May 23, 2019, 11:03:21 AM »
I did things incrementally.  First the smooth boss then the a larger jet (80-82).  These both came with the scooter when I purchased it.
Then I upgraded the exhaust and installed the Polini Hi-Speed variator.
Got to 65km/h then I went the BBK route for more power/ a little extra speed.  I didn't have the expectation of doing 90km/h. I just want a steady 70km/h whcih was only 5 extra km/h
2015 Super 8 50R
72cc BBK
eamartin
« Reply #10 on: May 25, 2019, 01:02:16 PM »
Doing the mods incrementally,  did any of them NOT improve performance?
« Reply #11 on: May 25, 2019, 08:33:52 PM »
….initially select a scooter model with an engine size suitable for your speed expectations, and keep it stock!
Amen.
Tromper
  • Seattlish
« Reply #12 on: May 26, 2019, 01:38:01 AM »
Pretty much with the other folks on this one.  A 50cc 4 stroke's only gonna take ya so far.
If 50cc is your passion for whatever reason I'd be looking for a 2 stroke before doing more with this one.
If not then look into something with a bit bigger motor.
You can tweak 'em all ya want, in the end There's no replacement for displacement.
2008 SYM HD200 "Niwanibiz"
k9 S200 (Blue) "Max" (Sold)
AylmerFreerider
« Reply #13 on: May 26, 2019, 01:52:23 AM »
Amen.
Issue is license.  I can use my regular drivers license with this.  No need for a special license I would need for anything listed at bigger than 50cc
2015 Super 8 50R
72cc BBK
AylmerFreerider
« Reply #14 on: May 26, 2019, 01:54:41 AM »
Figured out the issue.  Needs a secondary gear upgrade.  Seems that with the 4T the limit them 65km/h
With the BBK the power is now there for the for a 10% upgrade.
Now to find the secondary gear
2015 Super 8 50R
72cc BBK
