so I tried an high volume air filter from Malossii.
connection
Ended up being to small to fit the carb. I was expecting a rubber gasket style but it was hard plastic. so in my ;how can I connect this mode I realized that it would fit the front of the current air box. Tried this, and it didn't go so well. The box has a natural reduction in the inlet that was basically choking the engine once I hit 50 km/h
So back to the old air filter, but I had bought these little 1" air filter plugs that I drill the air box cover out for and they pop in just in front of the air filter. This has seemed to help with the power a little. went back to the 6.5 gram rollers and now I am hitting 60 km/h fairly quickly and topping out at 67-68 km/h.
Curious if maybe going to 6.2 grams or doing a 6.2-6.5 mix would get me those last few km/h I am looking for?
Note that I had to switch out the tachometer for w new one as the batter in the first one died and wasn't replaceable. New one is. but it is showing 7600 at 67km/h and showed 7800 when I did hit 70km/h on a slight downhill.
