Author Topic: RPM  (Read 3410 times)
Nireen
RPM
« on: May 24, 2019, 05:20:30 PM »
I just talked to the dealer who got me my bike back in 2016 and I explained my RPM situation and he assured me not to stress over it as it won't hurt my bike.  Like I say it was like this from the start.  He thinks the wrong belt may have been put on it and this is reason for the top speed lowering.
Kat :)
Re: RPM
« Reply #1 on: May 24, 2019, 06:09:59 PM »
(Echo...echo...echooo!)
stuo
Re: RPM
« Reply #2 on: May 24, 2019, 06:12:31 PM »
Nonsense! Yes, don't stress over it but do fix the problem, as your engine will wear prematurely and your gasoline bill will increase. A wrong size belt (too long or too narrow) will cause the problem.
My experience with dealers is that they will tell you whatever it takes to get rid of you and your problem, or to make money from it.
2009 GV 250
Nireen
Re: RPM
« Reply #3 on: May 24, 2019, 06:34:32 PM »
Oh boy you guys are not telling me what I wanna hear!!! LOL!  Thanks I am taking it in Monday Morning to fix it.  I will make sure they make sure the belt is the right fit.
Kat :)
Nireen
Re: RPM
« Reply #4 on: May 24, 2019, 07:50:35 PM »
Yeah talked to a trusted mechanic and he said yes it is running to high and said it is likely my clutch and or belt.  He said the clutch may need rebuilt or replaced!?
Kat :)
Re: RPM
« Reply #5 on: May 24, 2019, 08:46:28 PM »
What Stuo said X2! Investigate the belt first. As long as the clutch is operating normally, leave it. Read the numbers off the belt if possible. Measure carefully if numbers are not readable.
Nireen
Re: RPM
« Reply #6 on: May 24, 2019, 09:43:39 PM »
what should the numbers be Karl? size belt?
I may not get any trips in this year by the way it is going here for me.  I was evicted yesterday from my apartment all because of a post on facebook that someone decided to show my landlord of me saying to my friends I need to find a place to live cause I am very sick here in this moldy apartment.  He got mad!!! told me to leave by July 1st. :( I never said a thing bad toward him or his name or anything.  Not a thing.  Frig! :( the worse of it all there is nothing out there to rent.  It has been so bad here for about 4 years with this rent situation. Sigh.  I just want to get on my bike and go. But I can't :)
Kat :)
stuo
Re: RPM
« Reply #7 on: May 24, 2019, 11:16:22 PM »
I just ordered a belt from these guys for my DT 300i:
http://www.madhornets.com/drive-belt-for-kymco-downtown-300-350-shadow-gti300-k-xct-nikita-kawasaki-j300-black/
According to the diagram of their belt the circumference around the outside of the belt is 103 centimeters and the width is 25 millimeters.
So sorry to read about your land lord problems.
2009 GV 250
Re: RPM
« Reply #8 on: May 25, 2019, 12:04:38 AM »
Last belt I put in a DT300i was a Mitsuboshi 1004 x 25 x 30 = 1004 mm circumference, 25 mm wide, 30 degree angle.
Re: RPM
« Reply #9 on: May 25, 2019, 12:13:17 AM »
Order Genuine Kymco replacement belt from Kymco dealer=should work well--just make sure you order for your model!
Re: RPM
« Reply #10 on: May 25, 2019, 12:15:59 AM »
Absolutely get a Kymco belt. It will be a Mitsuboshi like I described.
mousejunks
Re: RPM
« Reply #11 on: May 25, 2019, 05:22:41 AM »
100% get a genuine Kymco/Mitsuboshi belt
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
Nireen
Re: RPM
« Reply #12 on: May 25, 2019, 07:22:00 AM »
Thank you!
Kat :)
Nireen
Re: RPM
« Reply #13 on: May 25, 2019, 10:55:51 AM »
Tell me something if I take the cover off to see the belt should I be able to see the numbers size etc so i can check this myself.
Kat :)
Nireen
Re: RPM
« Reply #14 on: May 25, 2019, 12:29:06 PM »
Tried can't see a thing :P
Kat :)
