Thanks for the response guys, i will check my jet when i get a chance (i bet they restrict it there too in the newer models).
I can hit 50 but only on a long enough slope, otherwise it's 40-43 (depending on wind ahaha) and that is indicated of course. I have not gps tested it however i did have a friend follow me in a car and tell my i was going 45+ on flat grounds, so could it be that my speedometer is on the other side of the spectrum (lower indicated than true?)
Anyways, first things first, i am going to open up the carb and check the jet# (clean the carb while i am at it). I will keep you guys updated with my progress and purchases.
"edit" : do the pipes for the kymco super 9 have the same mounting points and cylinder connection? because the link posted by art says the pipe is for kymco super9.
