So, the scooter is laid up presently awaiting new parts (Mivv Exhaust with Cat plus the PAIR pipe which disintegrated and a few other odds and sods - I plan on keeping the breathing pretty stock and will just muck about with the CVT tuning), however the downtime is giving me an opportunity to look into some other things. Chief amongst which is the current top speed/vmax vs. peak revs which I think is a bit off.
When I brought the scoot home, I gave it the beans for a while and it was maxing out at an indicated 145kmh @ 8500 rpm. I know the speedos flatter the real speed so true vmax is likely to be at or just below 140kmh which is a little paltry it seems. Performance off the line was strong (at least it seeemed to be) but of course at the time I had no idea of peak power rpms and whether or not the scoot would accelerate whilst in that band. I can't test it at present either due to it being without exhaust etc.
Given that 160kmh is apparently commonly achievable with the X500i, 145kmh at 8500rpm seems to suggest that either the bike has been tinkered with/set up improperly or, (as I suspect), the belt and contra spring are both worn. I understand that peak power is achieved at around 7000rpm so presumably for longer legged cruising at a higher speed, the current situation would suggest that I should be aiming to reduce the max rpm and maybe go for heavier rollers/sliders and a new belt? (It has 26k miles on the clock so highly possible that the belt/variator might need replacing)
I'm going to pull the CVT along with changing a load of other bits in due course so before I shell out for the wrong bits and as CVTs are a new thing for me, I throw myself on the mercy of those with far greater experience.
Please could those familiar with the bike give me an indication as to whether this vmax/max rpm is the norm or if it's a bit off as I suspect and what I ought to look at first in order to try to get closer to the optimum?
TIA
Faversham
