Author Topic: zx50 fever carburettor wanted  (Read 1659 times)
steve w hebburn
« on: June 11, 2019, 08:44:13 PM »
hi,found some o rings worn out, & quite a bit of corrosion/dirt. just could not get the zx to run very well after electric choke switched off. so bought & fitted a replacement carb  to the zx today. from a north east uk breakers yard. came from a daelim 50. seems to work fine.but is fitted with a 75 main jet, while the zx carb has a 80 as standard. any problems with leaving 75 jet in ? otherwise i will change it.. regards, steve.
« Last Edit: June 14, 2019, 09:09:44 AM by steve w hebburn »
steve w hebburn
Re: zx50 fever carburettor wanted
« Reply #1 on: August 07, 2019, 04:08:55 PM »
hi, found a peugeot speedflight 50 carb fits. just change the main jet.( the daelim carb i fitted kept bogging down &  cutting out). new battery fitted as well. now fixed.
« Last Edit: August 07, 2019, 04:13:26 PM by steve w hebburn »
